Recommendation for budget amp
Discussion in 'AV Receivers & Amplifiers' started by ashearer, Mar 19, 2002.
  1. ashearer
    ashearer
    Feb 14, 2002
    244
    Binfield, Berkshire
    I would like to get an amp/receiver for use with my XBox/PS2. My requirements are that it has 5.1/DTS and at least two optical inputs. I can go up to about £400.
    Any recommendations?
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,629
    United Kingdom
    +2,233
    Have a look at the Denon, Yamaha, Marantz and Harmon Kardon range of amps.
    Specific models
    Denon 1802, 2802
    Yamaha AX620 etc
    Marantz 4200, 5200
    Harmon Kardon 3000, 4000 etc
  3. laurel
    laurel
    ashearer
    You'll probably get the usual Denon/Marantz answer here and I'm no exception! :D
    For your buget I would go for Marantz 5200.
    If you wanna save a few quid for games, try the 4200 which has everything you need and ample power for your games stuff.
    Laurel
  4. ashearer
    ashearer
    Feb 14, 2002
    244
    Binfield, Berkshire
    I am a big Denon fan but the 1602 only has one optical input so I am going to go for the Marantz SR4200.
    Thanks guys.
  5. laurel
    laurel
    It's a sound choice. (no pun intended).
    Laurel
    "A rose between two moderators"
  6. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,629
    United Kingdom
    +2,233
    Are you suggesting we´re thorns??;) :D
  7. laurel
    laurel
    Wouldn't dream of it my friend. ;)
    Although you were pretty sharp with the response. :D
    Laurel
    Mmmm.... might change my sig....
