recommendation for a low profile multi-speaker amp ?
Discussion in 'AV Receivers & Amplifiers' started by applevenus, Jun 12, 2005.
  1. applevenus
    applevenus
    I'm looking for a small, low-profile amp that I can use for multi-room distribution. It needs to have 3 sets of speaker outputs; only needs one line-level input; size is important as I want this to be as discrete as possible.
    Any models that I should investigate ? Doesn't have to be current model - am quite happy to purchase used on eBay or elsewhere.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    you need to look at MR amps mate Bose SA-1, is one option needs a pre-amp i think, Sonamp SAT275x3 is another, OPUS 500 DZM50 AMP, depends exactly what you need it to do
  3. FeisalK
    FeisalK
    Jun 9, 2005
    375
    KL
    +21
  4. applevenus
    applevenus
    Thanks I'll check those out.
    The speakers are already there - I'm trying to replace a Rotel amp with one set of speaker outputs which is connected to a 3-way speaker switch. The Rotel is also a big big - I'd like to hide it under the table where it can't be seen.
