The 1000 cad doesn’t include the sub. Just speakers. I was thinking in wall at the front. I can shift it all left a bit. Roughly 2500 overall for speakers, sub, and receiver.
if I went in ceiling surround behind and to the sides, does that rule out the atmos? Is it one or the other? I can do without atmos as I have never experienced it, but want the surround if possible.
Are there speakers that would be recommended for the room size? Should I increase my budget?
Yep increase budget if possible. I wouldn´t want to buy anything crap as you have to make holes in your walls.
You can`t have in-ceiling surrounds and Atmos. The surround l/r needs to be placed roughly at seated ear height or slightly higher at wall then. Atmos overhead speakers will go in-ceiling so you need to have the height difference between these two. See here:
This is UK based forum so quite tricky to know all the options there in Canada, but Polk is always popular choice in US/CAD and specifically this model. The RC55i is from cheaper range for surround l/r wall mounting if you still considering that.. If you stick with same brand you can save little by going cheaper effect channels. Most money should go to front three.
In-wall speaker
www.crutchfield.ca
In-wall centre channel speaker
www.crutchfield.ca
In-wall speakers
www.crutchfield.ca
Tv would need to be wall mounted quite high so you don´t compromise the in-wall center channel location. Keep in mind that it`s one of the most active speaker in your system and it shouldn´t go too low shooting your knees.
Klipsch is quite legendary brand in States/Canada. This in-wall model is similar to Reference Premiere range which is super popular. It´s basically LCR speaker so you would use two of those vertically upright as main L/R and third would go horizontally just below tv.
Klipsch PRO-250-RWP 5.25" In-Wall LCR Speaker - Each brings dynamic, powerful, detailed Reference Premiere sound to your home theater system.
gibbyselectronicsupermarket.ca
The legendary Klipsch sound from Reference Premiere is here for your in-home theater needs. Get a robust, theater-like experience with the PRO-250RPW.
www.klipsch.com
They do bundle deals if you buy 2-5 speakers with the installation kit. You need to ask deal for three speakers.
The Klipsch PRO-250RPW LCR brings dynamic, powerful, detailed Reference Premiere sound to your home theater system.All New, Bezel-Free Magnetic Grille.
Paradigm another legendary Canadian brand has cheaper LCR. No idea how decent this is.
The Paradigm H55-LCR in-wall speaker address the important considerations when selecting custom installation speakers: truly superior sound.
In-walls aren`t ever cheap. Klipsch would be my choice for movies. The RP is not harsh sounding. You can listen Klipsches in many shops like Best Buy (Reference Premiere not Reference range!) to get idea do you like the sound!
For subwoofer my vote would go to SVS PB1000 Pro if you can stretch the budget.
Canada SVS PB 1000 PRO Subwoofer BLACK [2021 MODEL] - Reference Subwoofer Performance Hits an All-Time Low. The original SVS PB-1000 rocked the subwoofer world with unparalleled performance at its price and beyond. Now, the PB-1000 Pro raises the bar even higher with greater low frequency...
www.electronicsforless.ca
If that is too much then the older model which is on sale open box, but it won´t be as good due to smaller driver. This was still considered the best 500$(US) sub earlier, spanking most cheaper 12" models easily! If you can opt for the Pro model then don´t think twice cause good subwoofer can make such massive difference if you enjoy action/scifi/horror stuff.
Canada SVS PB-1000 300 Watt DSP Controlled 10 Ported Subwoofer - Open Box - PB-1000: Deep bass that doesn't require deep pockets. Your movies and music have never sounded better. The PB-1000 develops more clean, tight low end than competitive subwoofers many times the price. Never boomy or...
The same dealer actually carries Klipsch speakers so i would urge you to ask package deal if you are intrested about them. The more you buy / spend the better discount! As always ask deals from as many shops as possible.. There is always air in the prices, use your business man skills!
Canada Klipsch PRO25RWLCR In-Wall Speaker Dual 5.25 Injection Molded Graphite IMG Woofer - Featuring dual 5.25 Injection Molded Graphite (IMG) Woofer and 1 Pivot Aluminum Dome ABS Tractrix® Horn-Loaded Tweeter, the PRO-25RW LCR brings incredible acoustics with the signature Klipsch sound...
I would say something like below Yamaha (850$) as minium would be ideal for av-receiver although this can do 5.2.2 system at most so something like Denon X3700H (1500$) would make more sense in long run as you can move it to your basement and power 9channels and if you add 2ch poweramp you can power 7.2.4 system! It also has preouts for poweramps so basically you can then run any type of system you wish if adding those... Another important thing would be the better room correction, but yeah it´s really tricky with such tight budget. So you have to make the compromise somewhere. I would want good speakers and sub for sure. The Yamaha is not bad!
www.visions.ca
