Recommend speakers for cyrus 8vs system
Discussion in 'Home Cinema Speakers' started by markclayton7, Aug 18, 2005.
  1. markclayton7
    markclayton7
    Aug 18, 2005
    2
    Can you help? I am looking for recommendations for floor standing speakers for my Cyrus system. I have a Cyrus 8vs amp and a Cyrus 8x CD, I listen to indie rock music and some dance stuff. The room I am in at the moment is around 20' by 16'.
    I currently have Celestion A2's that are factory prototypes. They are lacking in bass, they sound bright and lack definition. Some reviews have said the A2's are too bass heavy which has confused me.
    Reviews I've read have suggested Ruark Crusader ll, Castle Harlech S2, Spendor S5E, Quad 22L and Mission 782SE. I have never heard any of them.
    Do you have the same are a similar system to me and what are you using. Help would be greatly appreciated.
  2. Astaroth
    Astaroth
    Jun 22, 2004
    3,653
    2
    London
    +882
    Whilst I personally havent tested the combination the Spendor are frequently recommended for pairing with the Cyrus 8 series equipment - personally I think they are butt ugly but I guess it depends on what level of importants you put on sound quality -v- aesthetics
  3. russraff
    russraff
    Aug 1, 2000
    2,415
    Newcastle
    +63
    Cyrus's house sound is rather dry and detailed with fast pacing. This means that the mid range is often lean, and bass is accurate, but not as pronounced as other brands (NAD Arcam etc). This is no bad thing, but if you don't like this sound tyhen perhaps the source or amp should be replaced?
    However, you could use some tonally warmner sounding speakers, like Castle or KEF (havent heard the last two "Q" generations, but I seem to remember they had a more full bodied sound than neutral) to offset the less deirable elements. I would not reccomend the Quad and definetly not Ruark, given your comments. Ruark have a very lively balance (I have a full set of them). Dunno about Mission or Spendor, but word is Spendor are a good match for Cyrus as mentioned
    Russell
  4. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
    I second russraff. Cyrus should sound good with Spendor. Proac as well. A left-field choice would be Totem, lovely lush sound, just right with the lean Cyrus IMO.
  5. watchlotsdvd
    watchlotsdvd
    May I suggest you have a listen to Monitor Audio GR10 :clap: standmounters or if the G20 floorstanders fantastic speakers :cool: , I have the GR10's on Atacama Se6 stands have them hooked up to a CD8/8 Amp running on Cyrus speaker cables - sound amazing, great wide encompassing soundstage, great timing, the bass from these hard to belive, never thought such a small speaker could produce a deep rich and controlled bass. Speakers are lounge friendly look good, lots of good wood finished, very easy to drive with the Cyrus 8 amp.
    I listen to varied music - rock, indie, classical, reggae and jazz/blues.
    I also like the sound of the Spendors, as ever you need to go and demo.
    happy listening :)
  6. recruit
    recruit
    Speakers that work well with Cyrus Electronics are Spendor, ProAc, Monitor Audio & also i now use the new B&W 805S's which absolutely rock with Cyrus components, previously i ran ProAc Response D15's but the new B&W's sound even better.
    Regards
    John
  7. dynamic turtle
    dynamic turtle
    Mar 23, 2004
    1,524
    41
    Central London
    +17
    I would've thought something like the Epos M12.2 would do nicely. A very good all-rounder and competitively priced, IMHO. Dour, drab styling though.....
    Other than that, Kef XQ1 (can be a tad forward though) or Dynaudio 42/52 should be on your demo list.
    As for Castle, all I can say is that my friends' all-Cyrus system sounds as dull as ditchwater with Pembrokes on the end.
    Get the GR10's if you like speakers that sound really boxy :rolleyes:
    DT
  8. russraff
    russraff
    Aug 1, 2000
    2,415
    Newcastle
    +63
    I must admit, I thought that the gold centre was worse than the silver! But, each to their own.
    I reccomended the Castle range becasue the original post mentioned a bright character and pointed to a lack of perceived mid/bass. Castle purposefully make speakers that are warm sounding, so I thought that this would solve the bright problem. Going on from that, the Dynaudios and Epos range may still leave the poster with a brighter system.
    Again, I would change the source and amp if the sound is not right.
    Russell
  9. recruit
    recruit
    Yep, forgot Dynaudios they work extremly well with Cyrus and if i remember correctly they have demd them at shows with the Dynaudio 52SE, very nice indeedy...
  10. dynamic turtle
    dynamic turtle
    Mar 23, 2004
    1,524
    41
    Central London
    +17
    That might be the case, as my friend's Cyrus system is about 5 years old, not the latest VS/X badged stuff. I assume they've solved that "greyness" problem by now :)
    TBH, I recommended Dynaudio's more because of the poster's penchant for rock & dance music, rather than any specific synergy with Cyrus gear. They could indeed make for a brighter overall sound.....
    DT
  11. chevvies
    chevvies
    Aug 20, 2005
    81
    11
    Between London and Durham.
    +3
    I would heartily recommend Dynaudio as an excellent match for Cyrus.
  12. Dickster
    Dickster
    Oct 19, 2004
    105
    +4
    I'm a current, and very happy user of a pair of PMC's who's bass is absolutely fantastic.
    Just my two peneth's worth. Happy demoing. :thumbsup:
    Dickster
  13. music1st
    music1st
    Demo'd the Cyrus CD8x and 8vs with Linn Ninka last week. What a combination! Anyone want a Linn Movie Classik :eek:)
  14. Scott_Mac
    Scott_Mac
    Jul 4, 2005
    5,985
    2
    2
    Bromsgrove
    +584
    A few have suggested above, but i too would look at Dynaudio for that kind of music, i use Audience 42's and have had extensive demo's of all sorts...
    52Se or 72SE are fantastic speakers with amazing bass, but without sacrificing the fantastic mid and top end from Dynaudio..
    That said, ProAc and PMC would feature higly on my list :)
    What's the budget....
