Recommend some budget floorstanders......
Discussion in 'Home Cinema Speakers' started by wassap, Jul 24, 2003.
  1. wassap
    wassap
    Mar 13, 2002
    1,651
    38
    +16
    Hi guys, im looking for a bit of advice here, i was looking to have a massive hifi investment this summer, but i have diverted funds elsewhere, namely my car.
    I did have my eye on a set of quad 22l`s or b&w 604 s3`s, but alas that choice will wait till chrimbo.
    So on with my question, im looking for a set of floorstanders until chrimbo, no more than £150, pref around the £99 mark, looking at the specials i see alot of kef cresta or missions m?? what else can i look at?
    Any reccomendations??
    My current feeble setup is a marantz sr5300, and a toshiba sd220e, and an old marantz cd player cd63mkii i think.
    The other reccomendation is for a decent cd player, this i will look for later in the year, maybe a budget of 350 ish, or maybe separate dac and transport etc??
    Oh and this setup will be the fronts, for music and films!!
    Cheers for any info guys :)
  2. overfloe
    overfloe
    Apr 23, 2003
    230
    16
    Newcastle
    the mission m7 or the newer m3 range suits the sr5300 nicely.. m73i can be had for less than £150 but you might look for the m33 (replacement for the m73) which should be similarly priced. alternatively you can look for Tannoy MX3-M floorstand for around £140. also the Monitor Audio Bronze series might be worth checking out for.
  3. Hawklord
    Hawklord
    Feb 15, 2003
    3,518
    3
    Aldershot, Hampshire
    +286
  4. mike_cummi
    mike_cummi
    eltax liberty 5. About £100 from RS. Haven't heard them but they have received good reviews.
  5. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    mike_cummi - then don't recommend them!
    I'd agree that the M7 series from mission tends to work nicely with the SR5300, although try to opt for the M74i as opposed to the m73i as it's a far superior speaker.
    Can be had for under £200 from http://www.prcdirect.co.uk
  6. kilobulb
    kilobulb
    Jun 27, 2003
    587
    28
    North London
    +35
    m33s are £169.95 delivered from hifi store.
    You might want to give the Wharfedale Diamond 8.3s (£144.57 at qed) a listen as well as they are quite good
  7. wassap
    wassap
    Mar 13, 2002
    1,651
    38
    +16
    Oh damn i ordered the m73`s today for £109, mind you they are only a stop gap until christmas, so hopefully they will be ok!!
  8. wassap
    wassap
    Mar 13, 2002
    1,651
    38
    +16
    i wanted wharfedales 8.3`s, but i cant find them in stock anywhere, only at 199, for which i can get mission m74`s, which is a better speaker
