texasjohn
Hello folks,
I use a pair of B&W DM601 in my study, connected to an CA Azur 540R receiver. The receiver takes an optical feed from the PC and is just used for gaming/Spotify passthrough. Occasionally I use the tuner. I don't feel the need for 5.1 surround but the low end bass is certainly lacking with just the 601s in isolation.
The DM601 are sat on a fitted desk, about 1" from a solid wall, 5' apart. I'm sat about 12-15" back from them.
The DM601 are fine other than that so I am toying with the idea of buying an active subwoofer (used B&W AS2, ASW608), but either will probably be overkill for a 3m x 3m space.
I note some of the other B&W bookshelf/standmount are a little bigger and have a bass porthole below the woofer (685 model). Would these perhaps give me the extra bass I am looking for, without the need for a subwoofer?
Even a little Altec Lansing £40 PC speaker set (cheap featherlight speakers and a sub that used to sit under the desk) was much better in respect to bass response.
Budget is 'a couple of hundred quid' plus the value of the 601s (assuming the solution is different speakers that replace them).
Thanks in advance for your views.
