Question Recommend me some smart plugs
Discussion in 'Smart Home, Climate Control & Security Forum' started by Inked, Oct 15, 2017.
  1. Inked
    Inked
    Jan 3, 2006
    18,216
    20
    Behind you
    +7,551
    Looking to add some smart plugs that will work with Apple HomeKit, and Alexa.
    Mainly for use with our fans in the summer months (though they are still on most days at the moment as the house is still warm) and Halloween / Christmas lights
    Would prefer some that didn’t require another hub, what are people using / or can recommend?
  2. Shrimp_Stu
    Shrimp_Stu
    Feb 5, 2007
    32
    11
    +3
    I use tp-link HS110 and HS100 smart plugs (I have7 around the house) - all used for lamps in different rooms.
    Very easy to set up, no hub required and use the simple Kasa (iOS app) and can use schedules, away mode (simulates random on/off switching during selected time) and setting scenes.
    I believe this can be controlled via Alexa (although I don't have this).
    No faults/dropouts and can control when you are away from home too (app can be controlled on other wifi networks/3G/4G).
    Got mine via groupon, amazon and maplin when on special.
  3. davepuma
    davepuma
    Jun 24, 2004
    17,541
    +3,507
    I use a few TP-Link HS100 linked to my main AV kit, subwoofer and a few plugs around the house. They're compatible with Alexa and there is an app (Kasa) for IOS and Android to control them when you're out of the house. They have worked flawlessly for me.
    Edit - Shrip-Stu beat me to it.
  4. True Romance
    True Romance
    Feb 7, 2005
    6,973
    Wolverhampton
    +3,032
    Yep another vote for the TP link plugs. Keep meaning to order some more.
  5. Inked
    Inked
    Jan 3, 2006
    18,216
    20
    Behind you
    +7,551
  6. Markr123
    Markr123
    Oct 24, 2015
    105
    28
    Uk
    +45
    Yes, the TP link HS’s work flawlessly. Creating groups within Alexa app, I can control combination of wall sockets and hue bulbs with one command.
  7. WozzaUK
    WozzaUK
    Jun 29, 2005
    559
    43
    Birmingham
    +181
    Looking to try these and just wondered if you could connect a double plug into one of these? Thanks
  8. giffordpikes
    giffordpikes
    Jul 16, 2017
    251
    46
    Wiltshire, uk
    +174
    I have extension leads plugged into mine. Turns on my av kit no problem.
    The plugs themselves are quite bulky. I think an extension lead would be fine, but with a double adapter and 2 plugs hanging off it might look a mess. Assuming it stays in the wall. Depends where it is and if you can hide it. That would be the only issue I think. Don’t think you’d want any high load items plugged into that sort of thing anyway but if you did might want to check that. Can’t remember it off hand
  9. loopee
    loopee
    Dec 2, 2005
    488
    Essex
    +10
    Do these tp-link adaptors work with Apple Home and Siri? And what’s the different in the 100 and 110?
  10. giffordpikes
    giffordpikes
    Jul 16, 2017
    251
    46
    Wiltshire, uk
    +174
    Sorry dont use homekit so cant say. Mine is hooked up to Alexa and that works brilliantly. The difference between the HS100 and 110 is the 110 also provides energy monitoring.
  11. chriszzzzzz
    chriszzzzzz
    Jun 19, 2005
    1,099
    Coventry
    +83
