recommend me some glue
Discussion in 'General Chat' started by shoestring25, Sep 6, 2012.
  1. shoestring25
    shoestring25
    Feb 2, 2003
    4,362
    essex
    +763
    recommend me some glue need to glue metal to plastic. the metal will be about 1 inch square and once stuck the glue must be able to withstand a good tug.
    superglue is a bit brittle for the job.
  2. BB3Lions
    BB3Lions
    Apr 24, 2009
    14,610
    3
    +6,443
    Bdsm?
  3. sophies hero
    sophies hero
    May 5, 2011
    1,530
    coventry
    +222
    Gripfill?
  4. Bacus
    Bacus
    Dec 30, 2004
    8,931
    Close to the sea
    +2,902
    No more nails :)
  5. John7
    John7
    Aug 6, 2004
    2,767
    +939
    Araldite epoxy
  6. namuk
    namuk
    Oct 23, 2006
    22,187
    +4,332
