Recommend me budget amp
Discussion in 'AV Receivers & Amplifiers' started by Doctor Smith, Feb 10, 2009.
  1. Doctor Smith
    Doctor Smith
    Apr 3, 2007
    2,501
    Loughborough
    +272
    I currently have an onkyo 674
    I am looking for 3 hdmi in and 2 out, if they are expensive 1 out will be fine.
    Also I would like and amp that gives 6.1 sound out of hdmi.
  2. dwhite
    dwhite
    Dec 13, 2001
    7,414
    Whitehaven
    +1,805
    How do you intend to use the two HDMI outputs?
    You can get amps with two outputs, but AFAIK they are not independant and usually only one is active at a time. So you couldn't send two different outputs to two displays at the same time, and quite often you can't even send the same output to two displays at the same time. AIUI there more for use with a TV and PJ setup where only one display is in use at any time and saves you having to swap cables.
  3. pure_geordie
    pure_geordie
    Mar 13, 2006
    1,112
    +60
    Hello Doctor, How's your new HC5500.
    I have the Sony STR-DG820 and it works spot on with my 5500.
    4 HDMI in to 1 out.
    Thanks.
  4. Doctor Smith
    Doctor Smith
    Apr 3, 2007
    2,501
    Loughborough
    +272
    I flippin love the hc5500
    I want an amp so i can have tv out of one and PJ out of the other, save me from swapping the all the time
