Recommend me a Wireless router for using a PS3
Discussion in 'Networking & NAS' started by nickl360, Feb 10, 2009.
  1. nickl360
    nickl360
    Nov 6, 2008
    39
    Hello all,
    I'm after a new router to use my PS3 with as at the moment my VM connection keeps dropping out and I think it's the router.
    I used to have a Linksys WRT54GSv4 router, I thought that'd given up the ghost when I started using my PS3 with it I kept getting signed out of PSN with the error 8002AD23.
    I replaced that with a cheap Belkin from Comet as it had £10 off, reduced to £25. That hasn't solved the problem.
    My FIFA09 DNF record is now at over 25% and it's really starting to annoy me now...
    Any recommendations? Links to any offers appreciated.
  2. graystreet
    graystreet
    Dec 15, 2004
    1,089
    83
    Littlehampton, West Sussex
    +261
    Found this from a quick Google search. Which may be relevant to you.
    If not there are a lot of things to look at if you Google for "error 8002AD23".
  3. nickl360
    nickl360
    Nov 6, 2008
    39
    Cheers for the reply, I've gone through that setup and it still doesn't work.
    I've got my PS3 setup through a static IP (192.168.2.253) now on my Belkin router, it still drops out though!?
    I think the next step is to try the PS3 to the modem directly. Just a right ballache moving all the hardware to the spare room where the VM connection point is!
