Recommend me a Subwoofer connector
Discussion in 'Subwoofers' started by Belaggio, Sep 4, 2003.
  1. Belaggio
    Belaggio
    I've bought a B&W 675 sub and I want a good interconnect for it from my Amp (Yamaha A2).
    Can you recommend me a good one and does the length degrade performance (ooh err missus).
    thanks
  2. Belaggio
    Belaggio
    anyone??? {tumbleweeds drift past}
    Would a high quality phono to phono be sufficient?
  3. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Simple answer: yes.
    Provided it's not run parallel right next to a mains feed of any sort you will be ok.
  4. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    As ReTro suggests....any good quality phono interconnect will be sufficient...you don't need "dedicated" subwoofer interconnects...I just use an XLO(unscreened)Reference cable for mine.
  5. gingerone
    gingerone
    Dec 10, 2002
    2,567
    +388
    I just bought a qed psw sub cable for about £24 and I am amazed at the difference it made to my rel quake compared to the standard cable.
    The bass is cleaner deeper and far more tuneful.
    Best £24 I ever spent.
