Recommend me a small screen for games.
Discussion in 'Plasma TVs Forum' started by Phybron, Aug 31, 2004.
  1. Phybron
    Phybron
    Ok I've researched this for weeks, here there and everywhere else and I'm still not much wiser.
    I am looking to get a smallish widescreen (hence LCD) with a 16ms refresh rate and progressive scan would be a bonus, primarily for use with various consoles.
    I started thinking the Sharp LV22SV2E would be a winner, until I realised it's a bit out of date now and has been superseded by the LC22AD1E, but I'm not sure that has prog scan or if it's generally the best bet - reviews seem to be a bit thin on the ground still (can't find any).
    Any objective recommendations would be welcome - I realise this sort of thing gets asked too much on forum's but I did a search and couldn't find anything that was specifically helpful.
    :lease:
  2. fozziebear39
    fozziebear39
    Jan 3, 2003
    1,009
    Newton-le-Willows
    +49
    Sorry to make you think you got a reply :)
    I await the same information. Basically I want a TFT or CRT PC monitor that has s-video or component to plug in PS2 or XBOX
    Ta
  3. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    I have a 19" that does all that but its not Widescreen
  4. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    Relisys RLT1720 17" widescreen can be had for £400
  5. Phybron
    Phybron
    Cool. Don't think that has progressive scan though.
    Something like that sounds good - maybe a bit bigger though.
    Any other ideas?
