Recommend me a remote?
Discussion in 'Home Cinema Control & Remote Controls' started by dvdsubtitles, Dec 23, 2004.
  1. dvdsubtitles
    dvdsubtitles
    Hi Chaps,
    I need a remote. I have an all-pioneer system - 504 screen, 868 player, D814 amp, a pioneer DVD recorder and a pioneer freeview box (I forget the model numbers for the last two).
    So at the moment, I am juggling 3 to 5 remotes every time I want to do anything :suicide:
    As the system is all-pioneer, there is some cross-compatibility with the remotes but it seems to be extremely limited.
    Can someone recommend me a suitable universal remote with minimum functionality as follows:
    * Switch on/off from standby the freeview box, amp and screen simultaneously, with a slight delay between switching on screen and switching on freeview.
    * Synchronise screen inputs with audio inputs (eg. at the moment when I switch the screen to DVD, I have to also switch the amp to DVD audio with a separate remote.
    * volume control and usual stuff.
    I am not keen on pronto-type remotes as they are far too expensive. Is there something that can do this kind of thing for around £100 or less? I am not fussed about touch screens either - I would prefer buttons.
    Thanks in advance,
    Mat
  2. dvdsubtitles
    dvdsubtitles
    anybody?
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    harmony H655 or get the pio amp remote working most stuff and then DVDR should do rest (perhaps not FV) but H655 will do it all..
  4. dvdsubtitles
    dvdsubtitles
    H655 looks very interesting - thanks!!
    Cheers,
    Mat
  5. Ikki
    Ikki
    Feb 23, 2004
    1,173
    2
    67
    Lancs
    +95
    I echo Horny's comments - only £99 from Dixons (what a surprise :rotfl: ).
  6. Benrudd1
    Benrudd1
    Jan 19, 2003
    961
    Pembroke Dock
    +66
    HOME THEATER MASTER MX-500 here for £95.06 delivered.
    All hard buttons, a fantastic remote in my humble opinion :thumbsup:
  7. hao
    hao
    Got a H655 Yesterday from Currys for £99. Dont like it that much will send you (or anyone else) it for £75. Only used once.
