Recommend me a projector + screen for £500
stevied3268
Hi all,
As the title suggests please could you advise (a newbie to projection) a projector and screen for around £500?
We have just bought a house and are awaiting it to be built so i thought might as well design where to put a projector and screen to go with my home cinema system in the lounge.
The mrs has agreed to the idea (surprisingly) but i have been asked to try and purchase white products so it blends in with the ceiling colour.
Thanks :thumbsup:
Steve
stevied3268
Any suggestions guys?
I've been looking at the optoma 600x which comes in at 350ish new. I know it's not White but hey ho.
With 150 quid would I get a decent electronic screen?
Queens Pawn
The 600x is ok - I've got the white version 67n . Its a budget model so you get budget performance. Personally, I wouldn't bother with a custom screeen with a budget PJ, but you can get an ok one for £150.
Be careful with throw distances / screen sizes as the 600x/67n has some leeway with zooming to fit a screen but not much. You don't want to digitally crop if you can help it. Also consider the acer h5360 - it has 3D built in.
Podcast: Sony XH95 TV, Klipsch The Fives Speakers & Bias Light Reviews + Best of the Month
