Recommend me a new system please
Discussion in 'Home Cinema Buying & Building' started by Rogue227, May 6, 2007.
  1. Rogue227
    Rogue227
    Jan 1, 2006
    37
    I currently have a Sony DAV-SR1 home theatre system, which is hooked up to my Pioneer 506XDE, as well as my new Sky HD box.
    I've had a custom boxed-in-ledge built which will hide all my AV equipment, and the tv is wall mounted.
    The Sky HD box and the Pioneer's media box fit in the new boxed-in area, but the DAV-SR1 is HUUUUUGE and won't fit (I knew this when I drew up the plan for the boxed-in-ledge, I was planning on upgrading and wanted to keep the depth of the ledge down to a minimum).
    So, I'm looking for a new system to replace the Sony DAV-SR1, but it needs to meet the following criteria:
    • Must be similar in size to a Sky HD box
    • Must be able to use existing 5.1 speaker wire as it's run under the new hardwood floor
    • Preferably slot-in drive rather than tray style
    • Must have HDMI/Upscaling capability
    The existing speaker wire has connectors similar to phone leads (RJ25??) but presumably I can just cut them off if the new system doesn't support this?
    I'm not too fussed about cost, if it's worth it I'll pay it.
    Can anyone help me out?
    Rogue
