We're migrating the forum software to the next major version and this will require the site to be down for the best part of Monday 16th.
More details here. Apologies for the inconvenience.
Recommend me a good sub cable
Discussion in 'Subwoofers' started by Steve N, Oct 30, 2005.
  1. Steve N
    Steve N
    Feb 3, 2005
    10,972
    Peterborough
    +2,425
    As title.
    My current Ixos 1081 is too short for my new sub location so I've got to change it.
    I have loads of different cables at the back of my system so:-
    Should I go for a better cable with better shielding or will another (longer)1081 do the job just as well.
    Do pricey cables make a difference to a sub?
  2. Goofy
    Goofy
    Jan 10, 2005
    97
    Leeds
    I think good shielding is very important, particularly on longer cables and if you run them near power cables etc. I use a Mark Grant Cable (Powerbuys on this forum), which has worked very well - no humming, despite the cable running next to a some power cables. Also you can order them for any length you require - which I found handy. If you do a search of this forum, you will find some good feedback.
  3. bob1
    bob1
    Nov 7, 2002
    4,474
    Sheffield
    +133
    Or you could make your own and save some money, i have a 8m cable running under the floor.Its heavily sheilded and as worked without a fault on all three subs i have owned.I have tried a purpose made cable and could tell no difference other than it was cheaper made,the cables Mark Grant makes and sells will be better than most you can buy,one lead i opened up used very poor cable.
  4. Malky1903
    Malky1903
    Jul 2, 2003
    1,937
    48
    Aberdeen
    +65
    I have a 5 metre standard phono cable connected to my sub. Cost me £2 and I can tell no difference between that one and a 5 metre one I borrowed from a mate that cost £50
  5. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    24,017
    2
    The Fylde Coast
    +14,045
    I made a 15m cable using double shielded microphone cable which is very flexible. Cost me £11 including the plugs IIRC. Very happy with the end result.
  6. paulst10
    paulst10
    Dec 16, 2004
    12,889
    Essex
    +2,320
    i use a QED silver reference ( SR-SW ) for my pv1 and it sounds superb, cost about £70 for 3m
  7. recruit
    recruit
    Have a look at AUDIOQUEST work well for me...
  8. rszee
    rszee
    May 7, 2005
    194
    Kent
    +44
    I also use a QED SR-SW for my sub, great cable, runs along side the power cable for my sub with no interference what so ever.
  9. Steve N
    Steve N
    Feb 3, 2005
    10,972
    Peterborough
    +2,425
    Thanks guys.
    It looks as though this is not a crucial area except for interference from mains cables.
    I don't fancy making my own so will probably look at Mark Grants. Be nice to keep it in the (avforum) family.
  10. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,368
    63
    East Yorkshire, England
    +171
    That would be a good choice steve :thumbsup:
    The SVS Sub you have is worth it !
    Mark.
  11. AngelEyes
    AngelEyes
    Mar 23, 2004
    10,617
    Detached from reality
    +1,637
    mmmmmm SVS with Mark Grant Cables :thumbsup:
    ...hmmm that reminds me I still have one of your cables Mark :eek: Will send it back next week! Sorry.
