Recommend me a good battery charger
Discussion in 'Photography Forums' started by overfloe, May 9, 2003.
  1. overfloe
    overfloe
    Apr 23, 2003
    230
    16
    Newcastle
    Hi all,
    I recently bought 4 x Panasonic Pro+ 2000mAh batteries unfortunately they are not compatible with my Kodak K200 charger. Currently I'm charging the batteries using my friend's Sony BC-CS1 charger and so far so good.. So now I'm looking for a new universal battery charger that can charge 4 batteries at a time, with quick charging time and with auto timer as a plus.. Any ideas?
    Million thanks :blush:
  2. ajp558
    ajp558
    Apr 18, 2003
    125
    Fleet, Hampshire
    +8
    Overfloe,
    If all you need is a charger for AA & AAA batteries then how about one of the latest "intelligent" chargers which work out how much charge is needed rather than just charge for a set time?
    I recently bought one of these from 7dayshop.com. Extremely good so far & much, much cheaper than I could buy from anywhere else. I was fed up with poor charging from my old fast timed charger. This is extremely quick, small & comes with an adaptor to run from car ciggy lighter.
    I can certainly recommend it if you don't need it urgently as 7dayshop are based in Channel Islands hence no VAT & bargain prices. Took about a week for mine to arrive.
    link - http://www.7dayshop.com/catalog/product_info.php?manufacturers_id=&products_id=9571
    AJP.
  3. overfloe
    overfloe
    Apr 23, 2003
    230
    16
    Newcastle
    thanks for the info ajp558,
    unfortunately the charger comes with 4 batteries.. i don't need 'em as i have bought 4 x panasonic 2000mah batts (from 7dayshop too).. i just want charger, not charger+batts pack :(
  4. m@rk
    [email protected]
    Jan 3, 2002
    1,222
    83
    Lincolnshire
    +374
    There are 2 makes that seem to constantly get good reviews
    Maha and Ansmann
    For the Maha ones (I have one of these) I could only find one UK supplier at www.mahaenergy.co.uk and you can buy either the charger or a bundle including a set of batteries.
    Both these vendors produce 'intelligent' chargers that actually work out how much the batteries need charging and then drop to a trickle charge after that.
    The problem with many of the cheap chargers is that they just charge for a set amount of time regardless of the amount of charge left so you could fully charge your batteries, take them out of the charger, wait a few seconds and then put them back in and the charger would proceed to give them a full charge again. This is not good.
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,350
    Rainham Essex
    +2,441
    I've got the Ansmann Powerline 4 charger. It has changeable plugs so it can be used abroad (also multi voltage) and comes with 4 2000mAh AA batteries.
    I got it from www.fotosense.co.uk
    I know you said you only want the charger, but I'm sure you could sell the new batteries. When I was looking for a charger they all seemed to be supplied with batteries.
    Mark.
