Recommend me a Gfx card
Discussion in 'Computer Components' started by akane_1984, Apr 24, 2007.
  1. akane_1984
    akane_1984
    Oct 25, 2005
    6,177
    Belfast
    +168
    I currently have a Geforce 6600LE 256MB, I'am wanting to update so can you guys recommend me a good AGP gfx card? ?
    thanks.
  2. Chox1988
    Chox1988
    Mar 30, 2005
    16,793
    basingstoke
    +9,161
    A few questions- whats the rest of your pc like, how much do you want to spend?
    I guess you've heard of directx10 and 8 series nvidia cards so i would have said wait a little while and get a newer version of an 8 series card when they are a bit more universal, or get an 8800 340mb gts (go for the model above- the gtx, if you can afford it, very expensive though) if you need one now. Obviously dependant on your pc specs and power supply unit as this thing needs a lot of power but at best thats what you want, i wouldnt recommend a 7 series nvidia or ati card that are directx9 as they are going to be phased out over time and its just pointless upgrading to one now. Especially with games around the corner that will be directx10.
  3. reaper12
    reaper12
    Dec 4, 2006
    1,296
    63
    +119
    Abu, read his post again!! He is looking for an AGP card.
    Akane,
    Don't know how much you have to spend, but,
    Between £80 and £130 get the 7600GT, either the 512MB version or the 256MB whichever you can afford.
    Over £130 get the ATI 1950pro.
    Good luck
  4. alphaomega16
    alphaomega16
    May 17, 2005
    14,115
    163
    Southend on sea
    +3,757
    You got motherboard make/model that helps as they usually have a list of compatable cards.
  5. Chox1988
    Chox1988
    Mar 30, 2005
    16,793
    basingstoke
    +9,161
    sorry guys i must have been half asleep. yeh i take all that back, :suicide: .
  6. akane_1984
    akane_1984
    Oct 25, 2005
    6,177
    Belfast
    +168
    Hi its a GA-K8N Pro
