Recommend me a Budget player please, need to buy tomorrow.
Discussion in 'Blu-ray & DVD Players & Recorders' started by BuyingATV, Oct 17, 2004.
  1. BuyingATV
    BuyingATV
    I need a cheap player that will yeild a decent picture, unlike the £30 compacks I bougth at safeways that was shocking, when things panned down you could see things sort of in bars across and it made for a very mepggy picture, leaves and any nature thing looked terrible and im not a picture perfectionist, i know a cheap player ant gonna be great. All I require is RGB output, I dont need 5.1 or anthing like that.
    Im looking at that Pinonner dixons are doing, looks as good as any web deal. Or the Philips DVP520 which seems good for £49 at argos.
    My budget is a mere 30-50£.
    Thanks people
  2. BuyingATV
    BuyingATV
    hmm on curry's the PIONEER DV-2750 is listed as not having RGB output, thats wrong isnt it? its down from £119.99 to £49.99.
  3. charlaph
    charlaph
    May 29, 2003
    242
    Dundee
    Don't know if I'm too late, but some Tescos are selling the DVD 520 for £45. Every little counts and all that.
    Also, it'd be worth going to Sainsburys if there is one near you. They have the 520 at £50, plus my local store had (now sold out) DVD 630's for £45 - I bought one and can safely say this is a cracking little player and definitely better than the 510, despite costing less (if they have any)
  4. gur
    gur
    Nov 4, 2004
    104
    Sorry to jump in but after buying a 520 for the kitchen from Sainsbury, where do you enable RGB through scart? can't see anything in the setup menus :confused:
    Good little player for little cash, notcie sainsbury online has it for £45 inc free delivery :smashin:
  5. sboy66
    sboy66
    Try Panasonic s27, I ve got one and bought it after reading some reviews. All reviewers gave it excellent reports, easy to set up and I'm delighted with it's performance. You can shop around on the web around £60 delivered.
    Regards,
    sboy66
