Recommend me a AMP for a Samsung M87
Discussion in 'AV Receivers & Amplifiers' started by chronictank, Sep 19, 2007.
  1. chronictank
    chronictank
    Aug 1, 2007
    36
    Hi, apologies if this has been mentioned before but reading various reviews and recommedations on this forum i have narrowed down my choice of AV amp to a Sony STR-DG910 and just want to make sure its a good buy before i take the plunge
    Now the amp will be used for Xbox360 Premium, PS3 and Wii primarily, in addition i have a media pc attached for movies via VGA (swapping with the 360 atm).
    Is this amp a good choice for this setup? or do you guys recommend something else.
    The budget is around the £300 mark
    Thanks in advance
  2. smashmouse
    smashmouse
    Jan 4, 2007
    224
    Bristol
    +18
    Although magazine reviews aren't the best advice, I find them useful for guidance. New issue of What hi-fi comes out tomorrow with a review of that sony amp you mention.
    A bit more than the £400 mark, but have you considered an Onkyo 605? Been getting cracking reviews.
  3. chronictank
    chronictank
    Aug 1, 2007
    36
    I dont really want to spend more than £300 (i didnt want to spend more than £200 but i couldnt find a descent amp which has all i need for less)
    The main motivation is so i can plug all my kit into the amp to get 5.1 surround, rather than plugging it all into the TV and having stereo
  4. awlfc
    awlfc
    Jun 12, 2007
    122
    +10
    does any one no if the samsung AV-R710 is any good
