Recommend front ported floorstanding speakers
Discussion in 'Home Cinema Speakers' started by s70rmp, Jan 10, 2005.
  1. s70rmp
    s70rmp
    Oct 26, 2004
    558
    +19
    can anybody recommend any front ported floorstanding speakers
    for under £170 ?
    for use as hifi use only at 1st and then in a AV setup
    cheers
  2. Londondecca
    Londondecca
    Dec 21, 2003
    2,080
    +96
    Why 'front ported'?
    What is the rest of the system
  3. s70rmp
    s70rmp
    Oct 26, 2004
    558
    +19
    so not to disturb next door
    system poss pioneer 575a dvd, pioneer av amp
  4. Londondecca
    Londondecca
    Dec 21, 2003
    2,080
    +96
    I am not sure they are reflex loaded but a front port is not really going to quieten down the bass for your neighbours.
  5. s70rmp
    s70rmp
    Oct 26, 2004
    558
    +19
    the way the room is I would have to place the speakers about a foot from the wall which is the wall thats also my neighbours living room.
    I wont be turning the volume up loud, i just want to stop the sound bouncing on the wall.
