Recommend DVD Recorder.....please
Discussion in 'Blu-ray & DVD Players & Recorders' started by StevePn, Dec 15, 2004.
  1. StevePn
    StevePn
    Nov 15, 2004
    167
    Salisbury
    +5
    :lease:
    I wish to purchase a dvd recorder, can anyone recommend one for the following requirements!
    1-Price no more than £250.
    2-Would like to be able to play/record on dvd RW, but could make do with dvd RAM.
    3-I am a Panasonic fan, but would consider other brands.
    4-Not fussy about multi region.
    5-95% use for timeshifting TV.
    Thanks Steve
  2. evans
    evans
    Nov 24, 2002
    1,161
    48
    +36
    steve
    Recently purchased my first dvd recorder the jvc drm 10 and it is a very good machine. time slips with dvd ram (plays/records same time).Also records dvd rw- and plays everthing including dvd + rw and dvd+r disks no problem. It does have progressive scan but your tv must be compatible.
    downside: is the manual is quite large but you must read some of it to figure out what you are doing. Also the fan was on even on standby but fixed the problem by reading the manual. also there is rgb out but not in, so for viewing it is great but recording from rgb is missing. Having said that I recorded using the six hour mode and it was alot better than the normal vcr quality.
    price cost me 270 cyprus pounds but I see it is alot cheaper in most European countries.
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    I know you said that you didn't like Panasonic (I'm not a great fan myself !), but the E55 is a great little machine. DVD-RAM is much more versatile, and if you use the disks in caddies, then they will last even longer.
  4. jeff9999
    jeff9999
    Dec 13, 2004
    28
    Where are you getting your DVD Ram in caddies because they seem hard to find (at a reasonable cost)?
  5. thfccambs
    thfccambs
    Jul 17, 2002
    23,952
    White Hart Lane
    +6,898
    Nick_UK,he is a Panasonic fan. :thumbsup:
  6. NickRno77
    NickRno77
    Nov 11, 2004
    98
    Letchworth, Herts
    +8
    I have a JVC DR-MV1 VCR/DVD combo, the fan drives me up the wall, how did you turn the fan off in standby mode???
    Nick
  7. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    Just buy the Panny E55. It works, it's simple and, I hear on the grapevine, that it can, apparently, have a hard disk added! Just look at the E85 chassis and see what I mean. Does anybody know for sure???
    Anyway, back to the basics...It has RGB in and out. Outputs component with Progressive Scan. Plays a huge range of formats. Timeshifts perfectly. Outputs Audio optically and digitally. Upgrades RGB to Component. And it is a genuinely superb DVD player too. If you can't get caddy RAM discs, just get loose ones, but you need to look after them!
    £179 online from Comet. Free Delivery. And if it breaks, just take it to your local Comet to get it fixed! Great.
    Jimmy
  8. alex.lake
    alex.lake
    Dec 20, 2004
    22
    £179 from Comet????
  9. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    +9
    Sorry Guys!
    I got it at Comet 4 - 5 weeks ago for £179. Price back up to £199. It is, however available at Empire Direct for £176 + carriage.
    Jimmy
  10. DeadMan3000
    DeadMan3000
    If you can get a Pioneer 220S I can highly recommend it. I got mine for £170 from Richer Sounds and someone on the forum was kind enough to supply me with a multi-region firmware upgrade (Be aware this invalidates your warranty. But who usually checks?). You can get it for £199 inc free P&P with multi-region from some so online retailers so you don't have to worry about warranty issues. But they seem to be out of stock until after christmas.
    It is pretty sweet and dead easy to use. Does DVD-R and DVD-RW with play and record at the same time.
