silent ninja
Hello
I'm after a a pay as you go phone for under £60, but the cheaper the better. I will be using it on O2. It will mainly be used for making calls and texting, but if it has a decent camera that would be ideal. No music, sat nav, internet browsing or any other more advanced features are necessary as I have devices that do that stuff already. The phone needs to be a bit rugged so that it doesn't severely scratch easily because it will often be left in the bag with keys and change-- a cover may well do this but often they look rubbish. I'd want good battery life too considering it's a basic phone. I currently use the K800i (yes i know it's realllly old but i got it cheap, battery life not great though) but it's served me well and the camera is brilliant for those on-the-spot pics. Something similar would be ideal.
Oh, and I do not want Nokia!
