Recommend an SACD player for less than £300
Discussion in 'Hi-Fi Stereo Systems & Separates' started by johndon, Jul 9, 2005.
  1. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    Inspired by the release of War of the Worlds on SACD, I'm after an SACD player for less than £300.
    The player is to used ONLY for SACD as I've already got an Arcam CD33 and a DV79 for CD, DVD and DVD-Audio duties.
    All suggestions welcome as I know next to nothing about SACD players.
    John
  2. booktrunk
    booktrunk
    Feb 6, 2004
    623
    Leicestershire
    +3
    Spend £99 at Richer Sounds and get a Pioneer 575 dvd player?
    I'm sure you will get better, but much better for below £300, I don't know?
    Or one one of the cheap sony sacd players for £120-£150 again from Richer.
    I'm sure good midpriced ones that you are after exist but i'm not sure how much quality difference there is between these players and say a all in one like the Denon 3910 up at £800 to do dvd duties as well, and sell your DVD79 (even though I guess as you have a CD33 a Denon 3910 wouldn't match the rest of your kit).
    The Pioneer at £99 is so cheap you cannot really go wrong with it :)
    Steph
  3. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    Thanks for that Steph, I'll check out RS.
    John
  4. Mr_Sukebe
    Mr_Sukebe
    Mar 10, 2004
    2,397
    London
    +212
    I've dem'd a 575 against a mid range Marantz (DV6400 if I remember correctly). The 575 was pretty rubbish, even on SACD, whereas the 6400 was a match for my Naim CD player (6400 playing SACD, the Naim playing the equivalent CD). Note that it didn't sound the same, but overall was roughly on par.
    As a point, I do own a 575, which is presently used for DVD only duties.
  5. dynamic turtle
    dynamic turtle
    Mar 23, 2004
    1,524
    41
    Central London
    +17
    You might be able to pick up a 2nd or 3rd hand Denon 2900 for £300.
    Very good with SACD, imho. However, they are famous for being unreliable, so buyer beware!
    Alternatively, there are some Philips 963A's going for less than a ton, and they are supposed to be rather good.
    You should also check out the Pio 757ai, as that's supposed to be a pretty good all-rounder too - £300/£350 ish methinks....
    DT
