Speaker makers put these ratings on their speakers to inform you- 50w normally means nominal power, and the higher number of 200 refers to peak music power, ie, when you are playing that music loud because even a 50 watt rms amp can momentarily hit peakes of 105-200 watt for a short time and the speaker should be able to handle it without blowing. So yes you could use a 50 watt/ 70w/80w or more but no more than 200w and it'll work just fine.
They don't have to match exactly but its good practise to have an amp with slightly less power than your speakers can handle to allow for peak power headroom.
