Recommend a wireless router please....
Discussion in 'Xbox Forums' started by SanPedro, Sep 7, 2007.
  1. SanPedro
    SanPedro
    Jan 11, 2001
    4,544
    +531
    Can someone recommend a good wireless router for Xbox live.
    Current router is causing problems with NAT settings. But I also need a better wireless performance as my internet radio just doesn't seem to work well enough through the wireless extender added onto the current router.
    Would a Netgear DG834PN do the job?
  2. Munkey Boy
    Munkey Boy
    Nov 23, 2003
    16,960
    2
    2
    Manchester
    +4,473
    I'm running a Netgear DG834G at the moment, does fine.
    Here's a search on some other people's opinions: link.
  3. smallclanger
    smallclanger
    May 9, 2007
    2,246
    Southampton
    +463
    I was very happy with my Netgear DG834G until we upgraded to 8mb and it couldnt cope - it was a v1 hardware though.
    The new HomeHub we got free works very well with no problems. The UI lets you setup port forwarding etc.
  4. C225
    C225
    May 15, 2006
    6,290
    Linlithgow
    +785
    Same here and works fine for me.
  5. kismet110
    kismet110
    Feb 6, 2005
    2,364
    London, UK
    +389
    Another vote for the NetGear, been very good & the 'phone support (only needed it a couple of times in the early days) is excellent.
    On the rare occasion it does wobble a quick reboot & good as gold again....
  6. erniebert1
    erniebert1
    Jan 11, 2007
    930
    46
    +120
    I got a netgear DG834GT and works a treat for me aswell.
  7. WhiteHartMart
    WhiteHartMart
    Sep 2, 2005
    6,843
    +1,499
    I had the Netgear DG834PN ..... for about a day - didn't get on with it at all - poor wireless reception and moderate NAT at best.
    Replaced it with the DG834N - superb - great signal and an open NAT after I opend a couple of ports - took about 5 mins to get sorted - well recommended :thumbsup:
  8. The Hotspur
    The Hotspur
    Feb 12, 2007
    701
    28
    +52
    i use a linksys wrt54gsv4 and have never had any problems, didn't need any configuration or anything :). that's despite reading subsequently that they are not recommended.
  9. SportiveUK
    SportiveUK
    Sep 25, 2001
    923
    Essex
    +21
    Currently using a Buffalo Airstation AG108 and using "g" mode for my PC network and "a" mode for the 360. It has worked perfectly from day 1 and (touches wood quickly) in the 3 months I have been using it, I have not had to reset it once. It also works as an acces point so you could buy 2, connect one directly to the 360 and double the network bandwidth, good for streaming HD video.
    Gets a solid 9/10 from me :smashin:
