Recommend a top player!
Discussion in 'Blu-ray & DVD Players & Recorders' started by Paul D, May 16, 2001.
  1. Paul D
    Paul D
    Dec 27, 2000
    2,743
    Manchester
    +539
    I am after a new DVD player.
    I need it to give out "Component" video.
    It does NOT need progressive as it will be used with the "ISCANPRO".
    It must not have the chroma upsampling bug!.
    I want top quality output, in both sound and vision.(i don't want much do i!)
    Upto a £1000 max!
    Any suggestions would be gratefully received.
    PS don't tell my wife!
    [ 17-05-2001: Message edited by: fulabeer ]
  2. bishman
    bishman
    Mar 29, 2001
    4,904
    83
    hertford
    +174
    I believe you won't go far wrong with the DV88. It has component out and audio and video are superb.
    Not sure if it has chroma bug, although I can't notice the problem on examples which have been given. It only noticed ever so slightly if you paused and looked hard on my old Samsung, when things are moving can you really notice it? Personally I think it is a fuss about nothing, we were all dellighted with our pictures until some techy pointed it out.
    Maybe screen size has something to do with it, I have a Toshiba 32in wide. Might not be big enough.
    No doubt someone will pop up and say the DV88 does have the chroma bug, the difference is massive and they don't know how anyone could ever enjoy a movie with it present.
    Get a demo, and make your own mind up. All the best whichever way you go.
    Bishman
  3. Black 5
    Black 5
    Jul 19, 2000
    367
    19
    Isle of Man
    +3
    Top player is the Tag DVD32R, but you'd have to buy the wife something really expensive to compensate - I speak from experience :D
  4. Paul D
    Paul D
    Dec 27, 2000
    2,743
    Manchester
    +539
    LOL! :D
    I've edited the first post to a £1000 max, as i think i would have to buy my wife a new man to keep her happy with the price of the Maclaren!.
  5. dealmaker
    dealmaker
    Feb 21, 2001
    741
    nearly in Scotland!
    Whats the "Chroma Bug"???? -
    apologies for my ignorance.
  6. bishman
    bishman
    Mar 29, 2001
    4,904
    83
    hertford
    +174
  7. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    I agree with Bishman, the DV88 would get my vote at this price. The top Toshiba is also worth investigating but I like the idea of being able to update the Arcam at a later stage (and minimise the cash flow).
  8. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Just had another thought. If you are after component output, top sound and vision and are not bothered by Scart (RGB) and DVD audio then the Toshiba 9000 is a stunning player and it only costs £350 multi region. (The old top Toshiba before the 900 came out). I can honestly say I have only seen it bettered by a Tag. It was a rolls royce player when it came out with stunning reviews at £800 R2. Highly recommended.
  9. rigman
    rigman
    Dec 14, 2000
    2,901
    83
    East Yorkshire
    +91
    Is the Toshiba 9000 RCE compatible? I have also seen the ads and been tempted, especially as it will be used with a projector and I remember this machine getting high praise a year or so ago as having one of the best pictures available but it was the lack of a scart that put me off but now that would be irrelevant when used with a projector via the component output.
  10. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    RCE Compatibility will be down to how the 'chipping' is performed. One firms solution COULD be RCE compatible whereas another might not be. Check before you buy.
  11. Paul D
    Paul D
    Dec 27, 2000
    2,743
    Manchester
    +539
    Does the Toshiba 9000 have the chroma upsampling bug? if it does'nt, i may get a "RCE bypass" chipped one as you say its very cheap!.
