Recommend a sound card with digital COAX out?
Discussion in 'Computer Components' started by wyerd, Nov 27, 2004.
  1. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    Upstate New York. USA
    +27
    Can anyone recommend a good quality sound card with digital coax out? I'm using an Abit AN7 which has Optical S/PDIF out to my amp, but I've been told that Coax is better. Unfortunately, the mobo's audio header only has 2 S/PDIF pins on it, one for out and one for in, so I'm not sure if I can use these with a coax header bracket.
    The amp can do all the digital processing i.e. Dolby Digital, DTS etc. so all I need is digital pass-through.
    Thanks,
    David.
  2. APC
    APC
    M-Audio Audiophile 2496.
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Have they fixed the problems the Delta drivers had with SP2 yet do you know?
  4. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    +27
    I'm using XP SP2, so I'd like to know if there's a problem with drivers. Where did you hear about this and what was the problem KraGorn?
    I've just looked at the M-Audio website, and the latest drivers are October 1, 2004 5.10.00.0048a.
  5. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    Audiotrak 192 Prodigy works fine here,also has ASIO and although it's own sound quality isn't stunning,I use it for exactly what you'll be doing...digital output to a Processor.
  6. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    I'm only going on what I've read on on TheaterTek's forum and on AVS, people saying that SP2 caused drop-outs and stuttering with the 2496 drivers.
  7. APC
    APC
    I'm running the card with SP2 without a problem.
    One thing I was aware of from the past is that the card's SPDIF only plays nicely with DMA enabled, (and doesn't like PIO).
  8. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    This is one such thread on TheaterTek's forum where problems with drivers is discussed .. obviously the problem must be dependent on other system components if you're using SP2 without problems.
  9. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    +27
    Thanks for your input guys.
    I've decided to order the card as I'm running Zoom Player with WinDVD and I could go back to SP1 if I had to.
    Cheers,
    David.
  10. Ajax
    Ajax
    Feb 4, 2004
    170
    I have the same card and also get dropouts. I am using SP1 however. I did a fresh install of everything a fews weeks ago and all was well for about a week, then suddenly the sound dropouts started again!! None of the patches work and it does my head in.
    Ajax.
  11. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    +27
    Is this with TT2.0?
