Recommend a Multi Region Blu Ray Player
spikeyjac
Hi there looking for a cheap as chips blu ray player to play my region A discs, any recommendations?!
Jack :)
HD Elvis
Jack :)
You can buy region B players here http://www.mrmdvd.com/ which are modded to play region A discs. Can recommend Sony as they are quick and reliable.
:smashin:
spikeyjac
Tad expensive for me :(
Cheers anyway!
LV426
Administrator
Staff member
Your only other realistic choice is to import a region A player (and, if necessary, ensure you have a suitable power supply for 110v).
