Recommend a good monopod under £30
h4rri
I bought a cheapie from my local independant and it is great. However it only have a screw head [guess I could attach another head tho] and this means I have to remove the tripod plate from the body when I use it.
I would personally suggest you go for one with the same plate as your tripod so they are inter-changeable without hassle.
I tend to use mine alot but would use it more if I didn't have to detach the plate all the time.
Podcast: Reported HDMI 2.1 bugs, Audiolab Amp & LG LED Projector reviews + Best of the Month
