Recommend a good "mini" system for my kitchen
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Graham_S, Jan 24, 2005.
  1. Graham_S
    Graham_S
    I've just bought an Apple Airport Express to stream music to the kitchen from my PC. I'd like a reasonably small, reasonably cheap system to play it. Let's say £200-£300 or so, but my budget is quite flexible if there's something worthwhile at a higher price point . I guess it would be nice to have a digital input, as I understand it you can get a mini-toslink cable for the AX. A tuner (doesn't have to be digital) and a CD player would be nice for occasional use too, but aren't essential.
    Any suggestions?
    Thanks for any help you can offer.
  2. Graham_S
    Graham_S
    OK. I've gone for the Denon M31: it seems to do well in the What HiFi awards. No optical input, but it seems that that sort of audio equipment doesn't feature those anyway. Well, that's what having a look at the back of a load of them in John Lewis tells me, anyway.
  3. Tejstar
    Tejstar
    Dec 4, 2002
    22,517
    London
    +1,005
    Did you go with the speakers too or are you buying your own?
  4. Graham_S
    Graham_S
    I bought the speakers too. Was that wrong?
  5. deanym
    deanym
    May 29, 2004
    1,789
    +141
    Bought a DM31 too. Partnered them with Monitor Audio B1's instead of the stock speakers and got a great sound. Decent speaker stands is the key here. If they match the kitchen of course!
  6. AMc
    AMc
    Nov 20, 2000
    5,714
    Near Norwich
    +2,256
    We use a TEAC reference 250 with or iPod - sounds good. CD and DAB are also good but the interface to the radio is a bit odd.
  7. johndon
    johndon
    Feb 3, 2002
    1,930
    48
    +89
    I've got the Denon M31 with standard speakers and for general background listening it's very good.
    John
  8. Tejstar
    Tejstar
    Dec 4, 2002
    22,517
    London
    +1,005
    The speakers supplied are very good (mission ones if I remember) others however mix and match. one of my friends even used a Quad 11L with it :eek:
  9. Noswar
    Noswar
    I have just bought a Denon 101 for my kitchen. Bit more expensive than the 31 BUT it is smaller in depth - 25cm so it will fit on a standard kitchen wall cupboard shelf.
  10. tom_nieto
    tom_nieto
    May 21, 2003
    418
    Brighton
    Have you looked into the Linn classik? That's a more upmarket mini system, and are meant to be very good.
  11. karkus30
    karkus30
    Jul 29, 2002
    13,991
    +1,261
    Get a juicer instead, far healthier and the noise they make as you pulverise a carrot or mascerate an apple is fantastic.
