Recommend a Garden Strimmer
johnny70
Moved to a rental property a few weeks ago, the garden is a mess, lots of weeds, some (long) grass. Needs a real trim before we can get started on making it semi nice. Garden is small ish.
So could you recommend a decent Strimmer please, prefer Electric as I'm not wanting petrol if I can help it.
Shooter1
I've got a cordless Bosch strimmer, which works really well.
I bloody hate leads, which my mower has. They always, always get tangled.
D
Deleted member 27989
I hate leads as well. Especially for a strimmer. I gave mine away after two uses and bought a ryobi four stroke petrol one. The person I gave it away to has also given my electric away :)
It was a Bosch it did do the strimmering just fine, avoiding the cable is a right pain in the backside as is moving the lead around the garden.
KyleS1
The Bosch 30-36 LI is a beast but might be overkill. It's the one I'm going to get next.
I've got one of the older Bosch ones with the ni-cad batteries that is decent but think all the current ones have lithium ion batteries now so no point giving my model number. Any of the Bosch cordless ones should be fine.
EndlessWaves
It might be worth hiring a heavy duty one if you've got some tough vegetation to get through. In my experience normal models tend to jam frequently if you use them for more than light clearance and grass edging.
spinaltap
I use a Ryobi cordless strimmer...
...but if your garden is severely overgrown, a Ryobi cordless brush cutter/strimmer might be more appropriate.
KyleS1
What's your budget?
IronGiant
A cordless electric is probably fine for the occasional trim, but not to tackle an overgrown mess. Would you consider hiring a proper brush cutter (petrol) to hack it all down and then invest in an electric (corded or cordless) to keep it tidy?
KyleS1
The 36v Bosch I mentioned above is a beast. I used one at work the other day.
Qactuar
I don't suppose you know if the batteries are interchangeable with other Bosch tools do you? I know some brands are keen on the "one for all" approach, and I have two from my Bosch drill...
KyleS1
Probably a different size for drills and strimmers. I could try and find out if you want.
aerodynamic18
I have the titan strimmer from screwfix and it's working great 2yrs on. Came with a hedge trimmer attachment and I just bought the mini chainsaw attachment for it. If it breaks I'll deff buy another for the money :)
IronGiant
The 36V batteries are for there heavy duty lawn mowers, chain saws and strimmers. I suspect your drill batteries are 18V like mine and although they do do a strimmer that takes the 18V batterry it's for light duties only and uses bespoke (and expensive) plastic blades, rather than standard nylon cord.
see here: BOSCH Genuine Rotak Battery (36V-Li, 4.0Ah) (+53% More Runtime) (To Fit: All Bosch Cordless 36V-Li Garden Tools - View the List Below) c/w Pair of Rotak Gardening Gloves + Cadbury Chocolate Bar: Amazon.co.uk: DIY & Tools
KyleS1
Saved me a job, thanks IG! :)
I have the 18v strimmer with plastic blades. It fairly decent but won't do anything hardcore.
Qactuar
Yes, 18v indeed - and that's all I need really so thanks for that - "Power 4 All" is their branding and it looks spot on. I'm in!
IronGiant
I think he was sorted out in July 2017 :D
Latest News
Sky set to launch its plug-and-play Sky Stream solution
  • By Ian Collen
  • Published
Movies Podcast: 26th September 2022
  • By Phil Hinton
  • Published
AV Podcast: 26th September 2022
  • By Phil Hinton
  • Published
REL Acoustics announces new Serie HT subwoofer trio
  • By Ian Collen
  • Published
Marantz set to launch new Cinema Series of AV receivers
  • By Ian Collen
  • Published
