Recommend a dual DVI Vid Card able to do 1680 x 1050?
Discussion in 'Desktop & Laptop Computers Forum' started by 337GUS, Aug 3, 2005.
  1. 337GUS
    337GUS
    Nov 1, 2000
    753
    NE Scotland
    +38
    Just replaced my 3 x 17 inch 1280 screens with 2 x 20 inch 1680 widescreen ones - Acer 2032WM - very nice screen!
    I have a Matrox Parheilia and unfortunately it only does 1600 over DVI :oops:
    Anyone know what card I can get with good image quality which does at least 1680 x 2 over DVI? Using AGP slot.
    May bite the bullet and go AMD64X2 though if the card is PCI-E.
    Gus
  2. iZombine
    iZombine
    Jan 21, 2005
    873
    28
    +33
  3. 337GUS
    337GUS
    Nov 1, 2000
    753
    NE Scotland
    +38
    Thanks Reznor
    Budget flexible, this is my work PC, I am self employed so spend up to 18 hours per day 7 days a week on it.
    Had a look at overclockers and a few other sites but they seem to miss out what resolutions the cards can do over dvi dual head.
    Was thinking about a 6800 pro agp at overclockers for £80 as a stop gap.
    Not into games, hence the Matrox Parhelia was an ideal card, may end up selling the 20 inch widescreens and going to 20 inch normal 1600's.
    Gus
  4. Son of Shaft
    Son of Shaft
    Mar 11, 2005
    157
    Breda
