Recommend a DAB
Discussion in 'Music Streamers' started by [email protected], Jan 13, 2005.
  1. nic@highgroundd
    [email protected]
    Jan 10, 2005
    182
    +3
    Audiophiles,
    could anyone kindly recommend a 'small' (half/size of slimline DVD for e.g.) DAB radio 'with' built-in amp. i.e. DAB radio with L and R audio out.
    Will be played at low'ish volume primarily.
    Tough brief, a challenge say.
  2. CJROSS
    CJROSS
    Nov 16, 2000
    5,102
    +343
    Humax 8000T. Freeview TV/Radio PVT Set top box. Or a Sony V8000 STB.
    Sorry not DABs as such, but better solutions audio wise due to higher tranmission rates than DAB. Good luck dude.
  3. northernmunki
    northernmunki
    not sure I follow your requirements exactly but the Pure DRX 601ESM is a half width DAB tuner, remote control, digi and analogue outputs. You say built in amp but then say audio L and R out as if you mean line level.
    I've got one, its nice.
