I’ve decided I would like a budget turntable set up. I have an old Cambridge Audio P70 amp with a built in phono stage. I’ve been looking at secondhand turntable options but I’m beginning to think that some of the more simple budget turntables may be a better option. I was thinking of a budget of around £200 but have some flexibility. I’m not worried about Bluetooth or USB connectivity and I’ll mainly be playing albums I don’t really need an automatic tone arm or speed change switch. I also can’t see myself spending hundreds to upgrade the cartridge in the future.
Ideally I’d like something that will look fairly simple, with the money going on best components for the price rather than extra features.
I had decided to go for the Pro-Ject Primary E but was talked out of it a little when talking to an assistant in a hifi shop, citing the fiddliness of the drive belt. An automatic Sony or Audio Technica was recommended. The LP120 is a little ‘DJ’ in appearance and not really what I had in mind.
I’m now thinking maybe a Rega Planar P1. Do you think this is a good option or would I be better spending a little more for the P2 or another option? Is second hand too risky? (May be able to get a Rega P3 for £300 but I’m not sure of the age)
I don’t know enough about turntables to know where the best value/quality lies!
