Recommend a BUDGET 28" TV
Discussion in 'TVs' started by southpaw, Aug 16, 2004.
  1. southpaw
    southpaw
    May 4, 2002
    293
    +3
    Can anyone recommend a GOOD 28" Widescreen tv for between ideally £200 - £300 or a max £400.
    I'm looking for a good tv at a good price. A good brand with as much as possible.
    I have had a look around and can get either a 50 or 100mHz Flat screen for £300 - £400.
    However would really appreciate your recommendations.Have been looking at Samsung, LG and Jvc so far.
  2. Grenaldo
    Grenaldo
    I got advised off a senior member that the Jvc AV28X4S was great value for money 28 incher and a very good picture quality, thats a 100hz flatscreen for £400 at empiredirect.co.uk, will be getting it myself
  3. Breeza
    Breeza
    Oct 13, 2000
    108
    +7
  4. Grenaldo
    Grenaldo
  5. Grenaldo
    Grenaldo
  6. rooney
    rooney
    Mar 7, 2004
    506
    midlands
    +33
    i bought two 32 inch pacific tvs from asda £350 each for spare tvs and system link xbox.for the price you cant go wrong .
    at the moment they are selling the pacific 28 inch for £175
  7. TV Headache
    TV Headache
    Mar 3, 2004
    242
    16
    You can go wrong if you have to replace it prematurely. And who are Pacific? What's their reputation for quality and customer satisfaction? Who will be able to repair them in a couple of years time? How long will the tube last? Where is their customer support based? What's the picture quality like? WHY IS IT SO CHEAP IN THE FIRST PLACE?? (There's always a reason!)
  8. rooney
    rooney
    Mar 7, 2004
    506
    midlands
    +33
    its a cheap tv from asda with a 1yr guarantee it does what it says on the box
    CHEAP TV
  9. TV Headache
    TV Headache
    Mar 3, 2004
    242
    16
    Cheap to buy doesn't necessarily mean that you get good value or will enjoy low cost of ownership.
    For my part I'd reccommend spending a little more and buying a Sony KD-28DL11. For sure it'll blow your budget (by £5!) but because it's an IDTV you won't need the additional cost (or complication) of a Freeview box.
    The quality is likely to be first rate since the near-identical DL10 model won a 5-star BEST BUY award from What Video Widescreen Entertainment and Sony TVs did very in the recent Which? reliability survey.
    If you're not interested in digital, there is a analogue-only version (KV-28CL10) which is even cheaper.
    It has a 50Hz picture but if you don't normally notice screen flicker then you don't need to wory about that. (Cheap 100Hz sets tend to show nasty side effects from 100Hz processing anyway).
    If you want the best picture quality and reliability that your budget will allow I'd wholeheartedly recomment either of these TVs.
