Recommend a 3M HDMI cable please
Discussion in 'Cables & Switches' started by GaryMo, Sep 22, 2007.
  1. GaryMo
    GaryMo
    Dec 18, 2005
    3,620
    Nr Manchester
    +280
    Can anybody recommend a middle of the road 3M HDMI cable, say around £40 maximum (if that's classed as middle of the road!).
  2. dan1979
    dan1979
    Sep 16, 2004
    3,539
    83
    +218
    Just get the cheapest one you can find.
  3. GaryMo
    GaryMo
    Dec 18, 2005
    3,620
    Nr Manchester
    +280
    Really? Many say go for the cheapest though other say quality still matters with a digital cable :S
  4. AnthonyG
    AnthonyG
    Nov 23, 2005
    8,855
    +1,188
    I am using this one for SkyHD.
    Going through a wall, past numerous electrical wires, twisted around two bends, and the PQ is indistinguishable from my £70 QED Quinex.
    HQ HDMI to HDMI Cable/Lead with Ferrites & Gold Plated 3m
    From what I have read it is only 5m+ that you need to start considering expensive HDMI cables.
  5. boltonbrowny
    boltonbrowny
    Believe me theres no need over such a short distance, I found this out at a cost, my expensive hdmi cable failed after 2 weeks plastered into the wall:mad: used the supplied skyhd hdmi while waiting for a replacement and found no difference in quality whatsoever imo.:(....if you really feel the need i can really recommend..
    http://www.futureshop.co.uk/hdmi-dvi-hdmi-to-hdmi-c-66_70.html
    Very apologetic about the cable and dispatched within a day
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,731
    The Borders
    +3,514
  7. GaryMo
    GaryMo
    Dec 18, 2005
    3,620
    Nr Manchester
    +280
    Cheers guys, some good money saving advice there!
    I'll be looking at buying a couple for a bedroom wall mounted 40" LCD TV though only one will be used with a DVD player for the moment. The other will be for potential future use.
