Recommend a 32" TV for around £600....
Discussion in 'Televisions' started by Skiddins, Jul 1, 2005.
  1. Skiddins
    Skiddins
    Feb 4, 2002
    100
    16
    Windsor, Berkshire, UK
    After an incident with my current Sony TV i need to replace it through insurance, they have allowed £610 as the value of a replacement.
    The TV they offered (presumably closest to my old one) was a KV32HX15, but I noticed the KV32FQ86S which was a bit more expensive, are either any good?
    Which TV's would you recommend for around this value or possibly slightly higher for a 32" Widescreen TV.
    I don't care about the manufacturer but I would like a 100Hz screen.
    Sound is not too important as I will be using an external surround amp etc.
    I haven't had a chance to look at the magazine reviews yet so any help will be gratefully received.
    Skiddins
  2. juicypears
    juicypears
    Buy a Toshiba 32ZP48! Absolutely the best for the money. Shop around there are loads of great deals!
  3. Skiddins
    Skiddins
    Feb 4, 2002
    100
    16
    lol, that's exactly the TV I've been looking at!
    Skiddins
