Recommend 49"/50" with viewing angle?
Ice_Black
I have been reading a few articles here and my understanding is I would need OLED for my living room? I would like a great viewing angle from all angles.
I have attached the floor plan where I am planning to place a TV on the wall.
Requirement:
Budget: £1300
120Hz 4K / HDR
Smart TV
For Gaming, Sport, Movies, and general use.
Watching SDs channel from Sky
HD and 4K from Netflix
Slim TV would be nice to have.
Size: 49" or 50". I don't think I can have any bigger - it is only 2.8m width
Ice_Black
Yes, even with the best LCD TV for viewing angles it will look a lot worse from your farthest sofa's than an OLED.
Look at a 48" OLEDs, but try to fit a 55" if you can since they tend to be cheaper, and larger.
Thanks.
Would LG OLED48CX or LG OLED55CX be a good choice?
Which would you also recommend from the Sony brand as well?
Dodgexander
Have you seen:
Definitely recommend LGs for all round usage, they have the edge for gaming over the others. Although to be honest you can't go wrong with any OLED and differences between one model and the next isn't with picture quality, because they are all using the same panels made by LG :)
Ice_Black
Have you seen:
Oh not seen that, I have seen you other thread created about best value.
I currently have Sony 49XH8505 in my bedroom and my experience Sony Smart TV is very nice and most important thing it is very fast (not slow)
How does that compare with LG in terms of speed and usability?
I might go with LG for a living room :)
I think 55" might be too big don't you think? It is only 2.8 wide and if you watch TV from Sofa it will be like 2.5 meters
Dodgexander
LGs webOS is more robust that Android TV. I personally like it better, but not everyone is the same. It will be fast the same as your Sony.
If you want another Android TV Sony and Philips do Android models. You may want to look at 55" instead of 48" though.
