Recommend 32" Plasma TV
Discussion in 'Plasma TVs Forum' started by hive81, Aug 8, 2004.
  1. hive81
    hive81
    Hi there. This is my first post he so i'd first like to say hi.
    I am currently looking for a 32" plasma TV which i will require to be wall mounted in my bedroom.
    I am looking to spend a max of £2.5k What seems to be the best Set st the moment rearding picture quality.
    Also i would like it to have digital inputs (DVI etc) as i would like to be able to hook my pc up to it if i want to.
    What do u people recommend?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    i would look at Panny 32" Veira LCD. only Hitachi/Sony/Philips do 32" plasma. also look at Sharp AD/G series LCD/ Samsung 32" LCd and JVC 32" LCD
  3. hive81
    hive81
    Is there any advantage in lcd over plasma? how about 37" plasmas?
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    lower power consumption, less risk of burn, more pixels.
    Also 37" plasma's 37Pe30 panny good for bedroom integrated analogue and digital tuner, or buy a 42" PW6 and enjoy it! with speaker and a couple of boards it will fill your budget, also much more choice in 42"
  5. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    At 37" the field increases. What Horny means is that he does not admire the 32" devices from these manufacturers, and thinks the LCDs are better. I wouldn't argue. At 37" the Panasonic Viera plasma is a respectable unit, and in another few months there will be a 7 series 37" monitor, no tuner, speakers etc, which lots of people prefer.
  6. hive81
    hive81
    So at around the 30"-32" lcd's are recommended over plasma sets? I would like to keep it around 30"-32" as my room is not very big.
    What are the recommend LCD sets in this size?
    Thanks for your help, its greatly appreciated
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    like i said before Panny Veira and Sharp AG series new phillips but havent seen them.
  8. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    The following have caught my eye, but not necessarily remained there...The final 3 I have not viewed in person. All are LCD except the Hitachi.
    In no particular order:
    Philips 32PF9986
    Hitachi 32PF5200 (not the 5300 which does not have usable DVI) - Plasma
    Panasonic Viera 32" - No DVI
    Philips 32PF9956 - a bit elusive this one. Not P+2 but other goodies, like HDMI instead
    Sharp LC-32GD1E
    Loewe Xelos SL 32 - a bit more £££ than you specified
    -Ian
  9. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,522
    Kent
    +830
    Got a brief peak at the Philips and Sharp on that list - both significantly better than the generation before them IMO and finally an LCD that can take a decent challenge to plasma.
    Would still rather a 42" Panasonic plasma though!!!!
