Recommend 28 inch widescreen?
Discussion in 'General TV Discussions Forum' started by ConradM, Jun 21, 2002.
  1. ConradM
    ConradM
    I'm looking to buy a 28 inch widescreen TV in the near future, I've got around £600 to spend (although cheaper would be good).
    I'm not too bothered about pro-logic, picture quality is the most important thing.
    I'd be grateful if you could recommend me what you think would be the best choice.
    Cheers :)
  2. Geoffc10
    Geoffc10
    What about the Panasonic 28 inch reviewed in the lastest Home Cinema Choice mag. The Geometry was spot on according to HCC. They said the sound was a bit crappy, but if you have an amp its not big problem.
  3. ConradM
    ConradM
    Thanks Geoff, I'll check it out.
