recomended speakers for rear EX pair under £100
Discussion in 'Home Cinema Speakers' started by shoestring25, Jun 1, 2003.
  1. shoestring25
    shoestring25
    Feb 2, 2003
    3,843
    essex
    +411
    Can anybody recommend a pair speakers for rear EX under £100?
    Must be as small as possible possibly satellites
    looking at eltax minis at the moment, open to suggestions though
    cheers
  2. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Eltax bipolars?
  3. ChrisNic
    ChrisNic
    May 11, 2003
    1,917
    63
    Thame
    +109
    I second the eltax bipolars, £50 from Richer Sounds at the moment.
  4. Hawklord
    Hawklord
    Feb 15, 2003
    3,530
    3
    Aldershot, Hampshire
    +294
    rear centre? or surrounds?
    both mine are in my sig and think you can pick up around your budget. Fit snuggly to the walls when mounted and are not intrusive atall. Give good performance too for the money- surround movenent is good and they get the job done.
