Recomended DVD recorder under £100 for a present???
Discussion in 'Blu-ray & DVD Players & Recorders' started by Jolly F, Jan 9, 2008.
  1. Jolly F
    Jolly F
    Sep 11, 2007
    124
    Can anyone recommend a good DVD recorder for under £100. I don't have much experiance with these and am a bit strapped at the moment to research it :(
    worth a try :)
  2. flashgordon1952
    flashgordon1952
    LG is under 100 but does not have a freeview tuner also look at goodmans maybe samsung have a cheapie also. all will not have HD or freeview tuners. try richer sounds Tescos
  3. jdp1962
    jdp1962
    May 31, 2007
    409
    +24
    I appreciate you are inexperienced, but for readers to advise you properly, you need to saywhat you want to use it for and what facilities you want it to have. For example:
    Do you want a Freeview digital tuner, or are you happy with analogue only?
    Do you want to record to a hard disk as well as to removable disks, or just to removeable disks?
    What connections do you need it to have, SCART, Component, HDMI etc...?
    You get the idea? Have a think, come back with more info about what you need it to do, and then people can give you better recommendations.
    :smashin:
