Recomendations for a Plasma
Discussion in 'Plasma TVs' started by AudioSlim, Dec 28, 2004.
  1. AudioSlim
    AudioSlim
    Dec 28, 2004
    1,060
    +76
    Hi All
    Could you just throw a few options at me please.
    I'm looking for a plamsa that is good for SKY+ HD (when it lands, have they sorted spec out yet?) but also will take a PC input and at decent res's as well. Not too well up on the whole res scenario with plasmas but if they do have native res's then Whatever x 1024 would be the requirement.
    I'm after the cheapest 42" (or even 50" for ideas) but that has a good picture, no point spending that sort of money and getting a ropey picture.
    Thanks all
    Slim
  2. madasahat
    madasahat
    Nov 21, 2004
    96
    go for a hitachi 42pd5200 a cracking screen with a brilliant picture :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap:
  3. grahamtriggs
    grahamtriggs
    Nov 19, 2002
    779
    28
    +33
    Yes, the specs for Sky HD are sorted - they are:
    720p and 1080i (broadcaster choice)
    50hz
    DVI-HDCP or HDMI connection
    At Xx1024 resolution, you are looking at an ALiS panel, NONE of which are suitable for Sky HD.
    The Hitachi does not do 720p@50hz via DVI/HDMI (IIRC), and at 1080i it cuts off the top and bottom of the picture.
    Your options are the LG 42PX12X, or Pioneer PDP-435XDE, possibly the NEC 42XR3, all of which have 1024x768 resolutions. The LG is by far the cheapest of the bunch, the Pioneer the most expensive. All of them can give good results, but it has to be your choice as to what works for you. Alternatively, you have the choice of 50inch screens from the same manufacturers.
  4. theo cupier
    theo cupier
    Sep 18, 2004
    1,649
    63
    Amersham, Bucks
    +113
    Posted at the same time as Grahamtriggs who put it so much better, so I've deleted my comments :oops:
  5. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Many plasmas can't handle 50Hz HDTV, which is not surprising, since the panels were developed for the American market. Just because a panel will accept a HDTV signal, it does not make it a HDTV. If you were to tune a car engine to run on aviation fuel, it would not make it capable of flight.
  6. grahamtriggs
    grahamtriggs
    Nov 19, 2002
    779
    28
    +33
    No - most panels can handle 50hz high resolution signals - but only via analogue inputs.
    Specs for HD services require digital inputs with HDCP protection - that's where the problem lies, supporting the required resolutions over the required inputs. There is no excuse for it, just stupidity / short-sightedness / greed on the part of the manufacturers.
  7. AudioSlim
    AudioSlim
    Dec 28, 2004
    1,060
    +76
    Thx for the fast replys and off too check the options out.
    Thx Slim
