Recomendation for DVD-R Media ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by RecordablDVDfan, Dec 23, 2003.
  1. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,902
    68
    +49
    I put in a bulkpaq DVD-R orange disk hit record and the E50 locked up after a minute and so I had to switch off / switch on again. Then I got the msg this disk is not supported or words similar
    Which makes work fine 100% ? I have a Verbatim DVD-R with stuff rec from another E50 and this plays fine..
  2. numskull
    numskull
    I've found that "ONE" DVD-R disks made by Datasafe from here to work perfectly in our E50 - at 60p each these are good value.
  3. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,902
    68
    +49
    Thanks. Great price but mad postage puts me off ;-( I only want 2 or 3 to test / try at the most for now...
  4. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    Try a quality disc with Ritek G04 dye.
  5. bobbles
    bobbles
    aviod bulkpaq like the plague
    I found that the cheaper discs are getting worse, even the ritek based ones
    I just sent 100 datasafe ritek ones back nearly all failed
    as lynx say don't go too cheap, it isn't worth it
  6. Jules
    Jules
    Oct 11, 2000
    5,566
    134
    +1,027
    The Ritek G03 and G04 discs are good discs, its just that the Panasonic machines are unusual in not liking them. So don't risk it... you'll end up wasting perfectly good discs as I did.
    If you burn them in a PC they'll play back fine in almost anything and last longer. I almost sent mine back, but I've kept them and
    archived my RAM recordings via PC to them.
    I've found the best disc to use on my Panasonic E60 is the datawrite classic grey (x2 speed)..... and I've tried loads of varying discs in large numbers. They're cheap too at around £12 for 25.
    Don't assume that other datawrites are the same, they're all different.
    e.g. the red top (x4 speed) burn and finalise ok, but if you don't do it all at once they fail. They also scratch easily and don't work too well in quite a few different machines.
    Stick with Ritek on the PC and Datawrite Classic Grey's on your Panasonic and you'll be fine.
    Once I stuck with this formula, I've been able to burn over 100 discs and not 1 coaster!
  7. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,902
    68
    +49
    You're keen! What are you burning dare I ask ?! http://www.blankdiscshop.co.uk/ have a good range of DVD-R and 9.4GB RAM disks I notice. I've ordered one of these as UK Horizons are repeating Jan 4th all 8 eps of Billy Connelly's World Tour of Australia. Great to have the whole series on 1 disk etc.
  8. Jules
    Jules
    Oct 11, 2000
    5,566
    134
    +1,027
    I've suprised my self how many discs I've needed to burn, but it's saved me a fortune.
    I've collected nearly 200 episodes of friends upto and including series 8, as these have been broadcasted on E4 every night for last few months. They would have cost me over £500, but 50 blank discs only cost around £30. Bargain!
    Also been recording loads of the old comedies on UK Gold for my Parents, the odd film and a few home movies made with my Sony camcorder... including my brothers wedding which had to be copied over and over for all our relatives.
    My disc usage will probably remain high over Christmas after which it will probably slow down.
    But by then, the Panasonic will have easily justified it's purchase.
    How did I ever live without it?
  9. numskull
    numskull
    Wel, it's still 60p for 50 disks INCLUDING postage, or they do a "Test" pack of 7 various discs for £6.35 inc postage:clap:
  10. kirk grubb
    kirk grubb
    Sep 6, 2001
    586
    +11
    Jules,
    Where do you buy your classic grey dvd-r from?
    I had a look at big pockets.co.uk and came across datawrite classic gen x2 at £13.50 for 25 (are they the classic greys ?), about to purchase them but final price was £19.50.Surely not £6 for delivery?
  11. Jules
    Jules
    Oct 11, 2000
    5,566
    134
    +1,027
    Kirk,
    Yes, those are the ones.
    I got mine from here but they've sold out at the moment.
    I paid £11.75 for 25 and paid £4 postage.
    Obviously the more you order at once the better as you only pay postage once. Buy a shed load and it makes more sense.
    Anyway, even at £19 it's worth it......still cheaper than Riteks and unlike the Riteks, the Panasonic loves 'em.
  12. bobbles
    bobbles
    series 1-7 can be had for just over £20 each so not quite £500 ;)
    but you are right recording TV series I would have bought has saved me a fortune. You obviously get the new series on dvd straight away.
    I now have almost every season of Seinfeld on disc which amazingly is not available on dvd
    As for useage going down after xmas. I doubt it. We will have some great new shows like Nip/Tuck. The handler.
    All the big shows are back too 24 / CSI / Friends etc
    The new channel FX looks superb. It is showing X-Files / Shield / NYPD Blue etc all from the start
    Thank heavens for dual record
    back to discs. I only every had 1 failure in 200 discs from the old tubs of 50 yellow datawrite.
