Question Recomendation for a new reliable AVR for MA radius hd
Discussion in 'AV Receivers & Amplifiers' started by mike012345, May 9, 2016.
  1. yamaha rxa 1050
    0 vote(s)
    0.0%
  2. yamaha rxa 2050
    0 vote(s)
    0.0%
  3. yamaha rxv 779
    0 vote(s)
    0.0%
  4. other
    0 vote(s)
    0.0%
  1. mike012345
    mike012345
    May 9, 2016
    x
    Could someone help me choose a new AVR for Monitor audio radius hd (r90hd10).
    My marantz sr5008 died so I would like to switch to another brand.
    Could someone recommend an AVR with good reliability, which would be suitable for MA r90hd10.
    I saw some old threads about yamaha AVRs which should work well with my speakers, however, non of these are available now, since these are old models.
    Options are: rx a750, rxv779, rxa 1050 or maybe even rxa2050.
    I would like the AVR to be equal to or better than the marantz in terms of performance, features and sound quality, but hopefully more reliable.
    Is there a point of getting a high power amp such as rxa2050 for my speakers.
    Also, the dealer offered a discount for an AVR+ two front speakers. Can I mix-match my current monitor hd with for example new radius r270 or MA silver 6? If I go for the 7.1 or 5.1 +2.0 , which AVR woud you suggest?
    Is there some other brand other than yamaha which can be considered reliable?
  2. Violator
    Violator
    Jun 19, 2007
    1,678
    116
    Chester
    +549
    I wouldn't mix-match your LCR.
    What budget do you have in mind for an AVR? Other than great sound is there anything else it needs to have?
  3. mike012345
    mike012345
    May 9, 2016
    x
    I was hoping to get the same or better features that the marantz had:
    -auto calibration
    -different cut off frequency for each speaker
    -DLNA, airplay etc. with High res file support
    - internet radio
    -4k and 3D compatibility
    -HDMI arc
    - WIFi remote app (windows/android)
    -If I were to expand to 7.1, front height processing would be nice, if this is possible.
    As for the budget, i wouldnt go higher than RXA 2050, but would be happy to pay less.
    If mixing LCR is a huge issue, I could live with the new radius center, but what could I do with the old one, then?
  4. Violator
    Violator
    Jun 19, 2007
    1,678
    116
    Chester
    +549
    Are you from the UK? Otherwise saying no higher than RXA 2050 will mean different prices.
  5. mike012345
    mike012345
    May 9, 2016
    x
    Its a yamaha AVR (~1500). I am not from UK - Greece.
    Yamaha AVR:
    RX-A2050 - AVENTAGE - Yamaha - Other European Countries
    Current speakers: R90HD10
