Recomend an all in one
Discussion in 'Home Cinema Buying & Building' started by petrolhead, Dec 19, 2004.
  1. petrolhead
    petrolhead
    Mar 29, 2002
    4,657
    Newcastle
    +103
    I currently have a separetes system in the bedroom but its just too darn large and takes up too much room. Tosh 520 DVD, Yamaha Amp and Yamaha Spakers, see my site for pics.
    I have up to £400 to spend but the speakers MUST
    be small/neat, SUB is not a problem
    Any sugestions?
  2. Ciaran500
    Ciaran500
    Denon DHT500SD
  3. wicket
    wicket
    Nov 23, 2004
    493
    Middlesbrough
    +10
    Yep, Denon DHT500SD, recommend it.
  4. petrolhead
    petrolhead
    Mar 29, 2002
    4,657
    Newcastle
    +103
    Somehow I thought that may be the answer but I thought it cost £500
  5. Judders
    Judders
    Oct 31, 2004
    154
    16
    Basingstoke
    I'd recommend it too. Had one for about 2 weeks now and love it :thumbsup:
    You can pick 'em up for nearer £400 if you shop around...avland 500SD
    You won't regret it, I promise :smashin:
  6. petrolhead
    petrolhead
    Mar 29, 2002
    4,657
    Newcastle
    +103
    Only thing is the speakers look like they are too deep
  7. wicket
    wicket
    Nov 23, 2004
    493
    Middlesbrough
    +10
    Mine cost £411 (with next day postage and free multiregion upgrade) from Peter Tyson online, I would definitely recommend them.
  8. petrolhead
    petrolhead
    Mar 29, 2002
    4,657
    Newcastle
    +103
    At 155mm I recon the speakers are too deep which is a shame
  9. Ciaran500
    Ciaran500
    How small are you looking for?
  10. runner125
    runner125
    Dec 13, 2004
    75
    +3
    I'd recommend the Denon dht500sd too - got mine for GBP 398 but it is now GBP 386.17 on QED-uk.com
  11. petrolhead
    petrolhead
    Mar 29, 2002
    4,657
    Newcastle
    +103
    Something thats no more than 120mm deep to match the depth of the plasma off the wall
  12. OldSkoO1
    OldSkoO1
    Nov 27, 2004
    565
    28
    +29
    500SD is a dream. Also bought from QED but would recommend you buy elsewhere, their after sales is a joke to say the least.
    [RANT]
    System works fine apart from random subtitles appearing on various dvd's without pressing anything. Sent it back in as faulty, they kept it for ages and they didnt find fault. Holding onto £400 of mine and left me with no unit/ Wouldnt refund and wouldnt replace therefore had to pay an extra £15 to get a new unit sent out. Absolute joke.
    [/RANT]
    I think sacraficing a few cm's will definatly do you plasma justice with a home cinema like this. You can of course remove the speaker mesh to shave off an extra 15mm or so. Its recommended anyway, the innards look sexy.
    Good luck
  13. Ciaran500
    Ciaran500
    If you take the mesh off them they are 140mm and if you felt like drilling a small hole in you wall you could fit the connectors at the back of the speaker into it. This would shave them down to under 125mm.
  14. petrolhead
    petrolhead
    Mar 29, 2002
    4,657
    Newcastle
    +103
    Hmm interesting
    Will go for a look
    How much do you thing I could get for a Toshiba 520 and Yamaha HTR 5540 and some Yamaha Speakers
  15. tightjock
    tightjock
    sony dav-sc5 £170 decent price,can supply shop web site
  16. pragmatic
    pragmatic
    Nov 9, 2004
    12,119
    +1,647
    The Panasonic DM-39 is good, got it for my parents plays everything under the sun. It is a hifi but plays DVD's well, it is only stero though with a psudo surround.
  17. petrolhead
    petrolhead
    Mar 29, 2002
    4,657
    Newcastle
    +103
    Nice idea but I can accomodate full surround
