Quantcast
recomend a GPU for my Dell Optiplex 980
rampant
Hi all,
i have got a Dell Optiplex 980, spec is as follows:
Intel Core i7 870 @2.93Ghz
8GB memory
Windows 7 64bit
The power supply is only 305 watts and has no molex connector on, so it needs to be one that doesnt draw much power or require a separate power.
I currently have a GeForce 9500 GS (dont laugh :) with 512mb ram on board.
I am looking at replacing the card, i am playing SWKOTR at 1280*1024, but would like to crank up the resolution to 1920*1080 and be able to play the game (rather than play in jerko-vision!)
Money wise i would like to keep well below £100 - if i could get away with a £30 card then this would be great :smashin:
Habanos
The Radeon HD 6670 only requires power from the motherboard, no additional power cable is needed. I think the 67xx cards need additional power.
Not sure about the nVidia cards.
I don't know how well they would perform in that game. The 6670 is going to be faster than your 9500GS, but whether it's fast enough to do 1920x1080 I don't know.
LJx
true the 6670 GDDR5 is the fastest card that doesn't need extra power, then there is the 5670 GDDR5 which is a little slower and costs a bit less too.
rampant
The motherboard has a non-standard mini molex power connector this makes it more difficult to update :(
The optiplex are designed as a business machine rather than a gaming machine :(
Sinbadio
hardforum.com/showthread.php?t=1538917
Try having a look through this forum, there are a few solutions in it that may be able to help. Also just to pet you know that the 16x lane is only wired at 4x.
rampant
yea i looked on there - just dont want to be modding the power supply so would rather stick with gfx cards that would work as it on it.
cheers
rampant
ive bought a 5570 1GB PCI-e from the classifieds ... according to the passmark website - it has double the performance of th 9500 GS :) - so should get a better gaming experience, as its like playing in jerk-o-vision!
shadowboxer
Great choice. A second hand 5770 is a great card for the money. Enjoy.
rampant
hehe - i can now play swtor on full resolution with no jerk-o-vision! (1920 * 1080)
i get a bit of slowdown when there is lots and lots on the screen, but generally exceptionally good!
GAZBEROTTEN
Hi all,
8GB memory
Windows 7 64bit
This may do you
OcUK GeForce GT 520 1024MB GDDR3 Low Profile PCI-Express Graphics Card []
Similar threads
