Recoding RGB ftrom IDTV
Discussion in 'Satellite TV, Sky TV & FreeSat' started by manhar, Nov 1, 2003.
  1. manhar
    manhar
    Oct 19, 2003
    163
    uk
    Sony IDTV
    How can I record RGB signals from the digital channels to my Philips DVD recorder?
    Setup:
    Aerial > Digital TV in > Loop thru to RF in of DVD Recoder
    Sky (Pace) Satellite RGB out > RGB in (AV2)of DVD Recorder
    RGB out (AV1) of DVD Recorder > RGB in (AV1) of TV socket
    There is one more RGB enabled socket on TV (AV2) unused
    I also have an extra Sony freeview digibox lying around unused
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    I think TV will only output composite mate i would use the Sony freeveiw box to record SONYFV>SKY>DVDR>TV should work but you cant watch sky and record FV at the same time. If you had Sky+ then it would be easier LOL
  3. manhar
    manhar
    Oct 19, 2003
    163
    uk
    1)How should I connect SonyFV to Skybox?
    2) BTW, Skybox has AV1 & AV2 out. Only AV1 out is RGB signal and it is this that feeds to the DVD recorder. If I connect SonyFV to skybox how does it overide the Sky signals going to DVD ?
  4. nwgarratt
    nwgarratt
    May 5, 2002
    26,443
    +2,871
    It will only do composite.
    I have a Sony IDTV and a E50 DVD recorder. It will also only do composite. I bought a freeview box and connected the TV out to the AV2 of the E50.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    Sky STB will do RGB passthrough when in stand by so sonyFV>AV2SKY-SKYAV!>DVDR>RGBTV SCART
    A Quintro could over come this as it has a VCR loop like a tape loop on a stereo amp you can watch one while sending another toa recording device. IIRC that is
  6. manhar
    manhar
    Oct 19, 2003
    163
    uk
    If I connect the RF out lead from SonyFV to RF out of DVD, will I be able to record digital RGB signal?. Or does RF out not carry RGB?
  7. nwgarratt
    nwgarratt
    May 5, 2002
    26,443
    +2,871
    RGB is only on scart.
  8. manhar
    manhar
    Oct 19, 2003
    163
    uk
    hornydragon, sonyFv>AV2sky-SkyAV1>DVDR>RGBTV works nicely but as u say u cant watch Sky when recording from Freeview digital. ie. on same TV. Interestingly, I have a Sky extension from the back of the Skybox to another TV upstairs and happily I find that I can record from Freeview downstairs and watch sky upstairs! Thanks for your help.
    Nwgarrat, thanks for your reply. I should have known that! Silly me.
  9. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    Early Sony IDTVs outputted RGB on AV1
  10. nwgarratt
    nwgarratt
    May 5, 2002
    26,443
    +2,871
    Not the DX20 and that is four years old in a couple of months. It only does composite.
