Reciever optical out.
Discussion in 'AV Receivers & Amplifiers' started by mi_july, Apr 5, 2005.
  1. mi_july
    mi_july
    Hi, Currently I have no DVD player going through my projector, instead I am using the vga out on my pc... this has to change. I currently do not have the money to use a dedicated speaker system, so as I am unfamiliar with Recievers can I output all my sound through the optical output and into my Z-5500, not exactly audio fidelity but it is all I can afford. If this is unclear please say, many thanks in advance
    Alex
  2. mi_july
    mi_july
    problem solved am going to use jamo a210pdd's its a small room and the reviews are gd so hopefully should sound better than my z5500
